Firmware Firmware v5.7.18 build 240924 for G5 platform cameras
alfaclvi
Knows a LOT of stuff
New firmware v5.7.18 build 240924, but this is only added for new motorized ones.
There is release notes and inside supported product list, there are all G5s included.
The good thing for those that can use GUI 5.0 firmwares(v5.7.17 and v5.7.18) is that except PTRZ, New and Modified functions, there are also some modification-improvements for the rest G5s.
Tried that too. But unforunately once again I'm back and stuck on v5.7.15 build240411. Got the same Dual VCA-Save VCA Data, issues for non Human and non Vehicle targets.
Cannot figure out if its NVR or Camera related
Tested this firmware v5.7.19 250218 yesterday on one ColorVU G5.
Dual VCA, Save Camera VCA Data not working once again. Smart search on NVR is useless.. I wonder why they keep this as a feature of cameras and NVRs..
Yeah I think that firmware only addresses some issue in the PTRZ models.
I've got two of the new 2347G3 models arriving in the next hour or so. They use a different firmware platform version, so it will be interesting to see whether Dual VCA will work on those. The only other AcuSense cameras I have where it works is the older G3 models that weren't updated beyond 5.6.820 so we'll know whether newer firmware on different platform has the feature or not....
G3s are not available in my country yet
Of course I would like to test one too. I'm waiting for your results..
But I will always wonder why they don't fix this Dual VCA info problem. They can't or they do not want to fix??....
They've just appeared here but some models are not yet. I can get the turrets but if I want live guard I'm stuck with 2.8mm (no 4mm yet), I think for the bullets only 2.8mm was available. I'm probably going to stick with the 4 MP models for better low light. There's also a 2647 upcoming that's of interest - 2.8 - 12mm with F1.2 rather than F1.0.
@alfaclvi - dual VCA search not working in this new H13U platform either....
I believe they have not understand the issue. Or this is what @trempa92 says about ISAPI and SDK based firmwares. Are GUI 5.0 firmwares ISAPI based?
