Hikvision cameras 12/16 MP
kruja
A large selection of models for 2026 (12/16 Mp).
I had a big problem, should I buy 4 or 8 MP.
-Hikvision DS-2CD23123G2-LI2UY/S(L)(RB)
-Hikvision DS-2CD23166G3-I(2U)Y
Hi @kruja
Thanks for sharing.
We were unaware of these new 12/16MP models.
We are speaking to our Hikvision UK contact to get more information on when these will be available in the UK and which model will be available.
There will probably be more information available in the New Year.
16MP with a 1/1.8" sensor, I'm surprised at that. I noticed that the new dark fighter turret (DS-2DC23x6G3) keeps the 1/1.8" for 8MP but for the 4MP models it's only 1/3".
It seems incredible. ,16 MP --- Color: 0.0008 Lux @ (F1.6, AGC ON),B/W: 0 Lux with IR.
The low light performance will be the trade off for the higher resolution. It's a 1/1.8" sensor and f1.6 aperture. A couple of other things that jump out from the product data:
  • Set to 16MP it's limited to 12.5 FPS
  • Set to 12MP it's limited to 20 FPS
  • If you want 25 FPS, you'll need to drop it the resolution to 8MP
  • The max bitrate is the same 16Mbps as always.
Of course I'm sure if they do become available in the UK, I'll jump in and get one to try....
16Mbps is bottleneck for 12 and 16MP
As well sensor size
I have put my 8MP camera to a bitrate test on highest quality
VBR showed at some points 40 mbits of traffic.
So if FPS doesnt bother you and night image. Regardless if you dont have 8K monitor to view the resolution, atleast on daytime you will have a good digital zoom detailed picture compared to 8MP.
It all comes down to what you actually need.
Done! - These 12 and 16MP models seem to be available now in the UK. I've just got one of the 16MP models:
DS-2CD23166G3-I2UY-SL (16MP turret with 2 way audio)
I'm not sure when I'll get chance to install it at mine as I'm not sure which camera I'll replace (most of the positions aren't the best). A couple of things I've noticed:
  • Viewing angles - from the spec sheet, the horizontal viewing angles are a fair amount narrower than their counterpart 4 and 8 MP models on that 1/1.8" sensor. They are 94 and 73 degrees respectively fro the 2.8mm/4mm as opposed to 111 and 95 on the 4MP ColorVu G3. Perhaps it's down to a different aspect ratio - not sure.
  • As mentioned before they have a similar minimum illumination figure to the 8MP ColorVu G2H at 0.0008 lux. However this model uses F1.6 aperture rather than F1.0. Hopefully it'll be sharper at closer distances.
  • As I mentioned above, the spec sheet shows a max bit rate of 16Mbps. The web interface of the camera however permits setting the max bitrate up to 24Mbps:
  • Edit: Once the camera is added to an NVR, the max bitrate tops out at 16Mbps, regardless of whether configuration is carried using the NVR/Virtual Host or directly on the camera.
The camera runs on G9 platform firmware. Latest firmware on Hik-Partner Pro is 5.8.3_260204, however my camera came on a later build - 5.8.3_260320.
I've had a quick glance through the menus. Exposure settings are similar to the ColorVu G3 models (H13 and H13U platform) using auto exposure with minimum and maximum exposure times configurable. A couple of things I've seen in the menus that differ from the ColorVu G3 platform:
  • Location. Latitude and Longitude can be set on the camera. That location info can be enabled for overlay in display options.
  • Audio Exception Detection is available in Smart Events. Audio Loss, Sudden Increase, Sudden Decrease can be used.
  • General Settings - Mounting Height can be set (default to 4.5m)
  • General Settings - Rather than just Device Number, Camera Number and Camera Information fields have been added.
I've installed the camera now replacing a 2347G3. On power up the picture was atrocious and I thought I'd got a lemon....until I realised this camera (despite being fixed lens) has a focus control.
It's bright and sunny currently but I'm still quite surprised after having a look at some playback. With the camera mounted at approx 2 metres, if I freeze playback I can read the number plate of a car passing at 25 - 30 mph - the distance from camera to plate is 20 metres (66 feet)
Not good so far with this camera. AcuSearch and AcuSeek not working with the VPro NVR - no results returned for any search. All configured correctly camera side, camera is enabled in engine. I’ve enabled/disabled AcuSeek, deleted/re-added the camera, unloaded the AcuSeek/AcuSearch engine, rebooted NVR and reloaded engine all to no avail.
This are indeed bad news. Have you checked if perhaps this model have acusearch disabled by default?
To my understanding, acuseek will work on camera which have acusearch option enabled in its settings.
Thats under VCA - > General parameters > Acusearch
@trempa92 - yes, it's on by default though as it's a newer camera the switch is marked 'AcuSeek' rather than 'AcuSearch' in that menu. Smart event metadata is also turned on.
I opened a case with Hikvision support this morning giving them all model numbers, firmware versions etc along with what I'd done to try and rectify it. I'll report back here if I get any useful response from them (unlikely!)
The quoted viewing angles on the datasheet are somewhat deceptive. I guess the figures given are for when the camera is set at 16MP; setting the camera to 8MP just crops the border of the image giving a much narrower view (and requiring the camera to be repositioned)
@trempa92 - as soon as I've dropped the resolution to 8MP, AcuSeek results started coming through immediately. It seems that it doesn't work when set to 16MP. Not sure whether that is a bug, a camera limitation or a NVR engine limitation. But still......not good
I really appreciate this information.
I was just about to treat myself to an 8ch nxi-i2 vpro and 16mp cameras so this is a real concern.
Just out of interest, when you dropped the recording resolution down to 8mp and you then got AcuSeek results immediately, can you remember if those results also included footage that had been taken when the camera was recording at 16mp ?
No. Unfortunately:
- 16MP - No results in search for either AcuSeek or AcuSearch
- Drop to 8MP - Indexing of new targets starts immediately and results are shown for all targets seen since the resolution drop (but 8MP image is a cropped image so doesn't show the previous viewing angle)
- Switch back to 16MP and the results stop coming through (previous results from when the cam was set to 8MP still available)
I've also confirmed that it doesn't work at the 12MP resolution either. Using ISAPI from terminal, the camera appears to send junk metadata when set above 8MP.
I submitted all information to Hikvision support including model numbers and serial numbers for both the NVR and camera. Later that day I got asked:
"what NVR model number and serial number is the camera connected to?
So I'm not expecting anything positive from Hikvision support if they fail to read the information provided.
Oh no, I was really hoping that you would say yes.
I was thinking that it might just be a bug when initialising an Acuseek search if the camera's set at 16mp.
I can't imagine that Hikvision would release these G3 16mp cameras knowing that they're incompatible with AcuSeek at 12 and 16mp, it just doesn't make sense.
Hopefully you'll make some progress with Hikvision and it's something that they can resolve but until then my system upgrade is definitely on hold
Thats why their 32MP Panovu didnt work out in my case...
Perhaps current firmware support up to 8MP
Right - all confirmed.
Hikvisions support initially requested I install the earlier build firmware and factory reset the camera. If that didn't work they would take a look at extracting debug from the camera so work out what's going on. I mentioned that I could get it [AcuSeek/AcuSearch] working at 8MP. After checking with the 'product specialist', they confirmed that it can only be used when set to 8MP and below, and that a firmware update would be released around Q3 that would enable it in higher resolutions (yeah right, like I believe any timeframe given by Hikvision)
The fact that I had to mess around with the camera, that there's nothing on the data sheet, no warning pop up in the camera and that Hikvision support themselves were unaware makes me think this is really not common knowledge.
So I've got to say that if you want AcuSeek/AcuSearch DO NOT purchase this camera. It's not a case of 'I'll set this up at 8MP until the firmware update drops' The crop on the sensor is extremely limiting (I'll update this post with pics shortly). It's similar to the very first 8MP models where you'd get a wide angle view at 8MP, but a centred crop at 5MP (that was the DS-2CD2385FWD-I from memory). On that model a later firmware update corrected that so that both images were the same.
Ill push from my side, we will see if we can get fw earlier, at least the custom version until official comes
So to confirm - here are the snapshots at different resolutions showing the cropping - 16MP, 12MP, 8MP. I'm a little confused as to why the HD snapshots at 16 and 12MP are much smaller than the resolution the camera is set to?
16MP "4608x3456" (it's in quotes as the HD snapshot is only 4096x3072) - Full View
12MP "4608x2592" (HD snapshot is only 4096x2304) - Height is cropped top and bottom
8MP "3840x2160" (HD snapshot is correct at 3840x2160) - Height and width is cropped
