bien gomez
- 38
- 6
I have some inquiries and I wanted to ask what is the possible solution to extend the IPCam to more than 100 meters from the NVR. Target quantity is about 50 to 55 IPCameras all in all
This will be a combination of multiple 16-port NVR.
All NVR must be accessible from the internet and local network as well
Inquiries:
-Some IPCameras may extend more than 100 meters from the NVR
If this is the case, I was thinking if this is possible
NVRs POE port --> POE switch --> IPCamera
OR
NVRs single LAN port -> POE switch --> IPCamera
I am not sure which is the best setup, connect the switch to any of the NVRs 16 port
or to its single LAN port.
-DSL speed
Also, if all the IPCameras are set to full resolution and it will be accessed over the internet,
what is the suggested internet bandwidth in order to provide an acceptable viewing experience
over the internet
-Network performance
If all of the IPCameras are operation, since they are all on a full resolution setting,
are there any other things that should I know about? I mean will this cause too much
network traffic and affect the local system (inventory/pos/biometric/etc.)
I am not yet familiar with a setup that is more than 4 IPCameras so I am hoping to get some information from those how are able to setup a similar scenario.
Thanks so much.
Inquiries:
OR
-DSL speed
over the internet
Thanks so much.
