Adding a Reolink POE Doorbell to Hikvision DS-7616NI-M2 / 16P?
digital
I've spent too much time trying to connect a Reolink POE doorbell camera to my DS-7616NI-M2 / 16P and have failed miserably. Anyone able to help with easy to follow instructions please?
Hi @digital
It looks like the Reolink POE doorbells support the ONVIF protocol, meaning you should be able to add it to your NVR.
However, your NVR will only treat it like a camera for saving footage, i.e. you won't be able to answer the doorbell via the NVR's interface.
  1. First, make sure the doorbell is connected to your local network (via WiFi or ethernet cable), and has a valid IP address on the network's range by following these instructions:
  2. Use this IP address to add the doorbell camera to your NVR via the "manual" adding method and "ONVIF" set as the protocol, as explained here:
    You may also need to check that ONVIF is enabled on the doorbell - there should be a setting somewhere in the port/network settings allowing you to toggle it on / off.
