Hi all
I had my newer model DS-7608NI-I2 /8P installed in April and used the 3TB Purple WD HDD from my previous NVR model and am running five cameras in total.
I have purchased an additional same model 3TB Purple WD drive to add as a second drive but when I power on the NVR the new hard drive gives out low noise beaps for a minute or so until the NVR has fully booted up.
When I then go to the storage setting on the NVR it does not see the second drive. I have used the same cable to connect to my existing first drive and that works fine and is only when the new second drive is connected.
can someone please advise as to what the issue might be as I haven’t managed to try connecting it to a different device to confirm whether it’s a faulty drive or the NVR is not accepting it before deciding to return it as I’ve had it fir about two months but just had the time to install it now whilst I was replacing both fans with Noctua ones to reduce the noise.
thank you.
thank you.
