Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
If you are only recording by event and the activity triggering that event is low/medium then 2TB should be ok, if you want to record continuously you will need more storage.
From our rough calculation 5 x 4MP cameras recording continuously using H.265+ and 15fps for 30 days will require around 5-6TB, you can do your own calculation using the Western Digital Capacity Calculator
There is minimal difference between the AcuSense & ColorVu, the biggest being that the AcuSense does not support the ColorVu technology including the white light. (it uses IR LEDs instead)
