I have several ANPR cameras but a single one has this strange issue which I have never encountered before:
The substream is set to 640x480 / Variable / Medium / 10fps / 512 Max bit rate.
The substream looks fine most of the time when there is no movement, but as soon as there is movement (e.g. a car passes) the substream goes very pixelated. I can see via iVMS that the bitrate normally is around 300kbps but during motion it drops to less than 100kbps.
I CAN work around this issue by setting the bitrate to constant but does anyone have any ideas why the substream changes like this?
I know for main stream you have setting which can change the bitrate between motion/no-motion but I have never encountered this on the substream.
It's a iDS-2CD7A26G0/P-IZHSY (H8) on the latest (UK) firmware v5.8.50 240806
