Arming live guard cameras via Ax Pro remote?
adamlavv
Is it possible to arm the live guard cameras connected to my NVR with a button on the Ax Pro remote, Ideally when I arm the Ax Pro the cameras will all arm at the same time.
Thank you.
Sorry there's been no response to your query.
Did you progress this at all?
There is possible solution if you would use any device in your AX PRO that have PGM or output then connected to NVR alarm input
Then you would do automation for Arming and Disarming to trigger that output on AX PRO/Peripheral
You can buy AX PRO Relays devices that can do that.
Now talking about software support, i dont think its possible yet, its only possible if cameras were added directly to partition and then you would be able to arm/disarm that partition.
Did anyone test this solution?
It will only work for the cameras connected to nvr or all visible in hikconnect ? What about other cameras connected to the router, how to arm/disarm them with ax pro ?What do you mean by "partition" ?
Would be possible to set a scenario on ax pro to for example on disarm 1 option disarm only 3 out of 6 cameras and on disarm 2 option 6 out of 6?
You add ip cameras directly to ax pro like you add them to nvr. Create partition 2 aka perimeter. And then any line crossing intrusion or etc from cameras will alarm ax pro if that partition is armed.
Would it be possible to add the cameras to AX Pro and at the same time utilise the Live Guard feature? As in, if AX Pro is armed, then Live Guard is on and the light and audio warning is on. The setup for the HikConnect app described here PDF file works, even when the "Notify surveillance centre" is ticked. However, it is unclear so far how to combine this with the AX Pro arming feature. Did anyone try this setup?
