Camera Access Via Browser - CONFUSED
gp116126
Centurion!
My cameras are connected directly into the ports of the NVR and I always use the NVR to access my cameras but I now want to via a Browser.
The equipment I have is using the follwoing IP addresses.
NVR ... ... 0 ..
Cameras ... ... 254 ..
Router Gateway ... ... 0 ..
3 cameras are Plug and Play and 2 manual setup but SADP shows only the NVR when I run it from PC.
So, with total confusion I have done the following.
With IP of the PC obtained automatically inserted camera IP address (all 5 separately) into Browser address widow but got time out on each occasion.
Changed the IP of PC to the same subnet of the cameras and did the same but no joy.
Could I have some assistance please.
NVR ... ... 0 ..
can you enable the virtual host?
Hello David
Yes, I can and now thanks to you can also access camera GUIs.
Thankx for your help, much apprecaited.
