I have a Hikvision CCTV box which can take up to 9 cameras
1 is a Dome IP Camera which we use through a Cat5 cable - trouble is, it is around 140m long....
It used to work fairly ok, allowing for a little stuttering sometimes, but now it has got worse.
I have a separate POE switch box which sends power and signal to the Dome Camera at the Hikvision end...... (we have also powered the IP Dome camera with a separate PS from the camera end with no difference)
I guess it is the LENGTH of cable that is the issue
Is there any Booster that could be put half way along the cable, or similar.
POE Ethernet Repeater ???
We have tested the cable for breaks and signal continuity
