R Roelli Active Member Messages 31 Points 8 Jun 23, 2020 #1 Hi. I have a Hikvision DS-2DE4A220IW-DE IP dome camera. And I can't turn on "WDR" anymore. It automatically disables itselfs. Reboot did not work. I tried IVMS, but there are zero adjustments possible. Any ideas? Here is a video: Thanks, Roelli.
R Roelli Active Member Messages 31 Points 8 Jun 23, 2020 Thread starter #3 Thanks!!! 265+ was NOT enabled. I turned it on and... WDR is working.
R Roelli Active Member Messages 31 Points 8 Jun 23, 2020 Thread starter #4 Oh.. but now the camera does not switch on the IR LEDs anymore? (no matter if I chose Day/Night Switch to "Auto" or not) And... the "IR Light Mode" Setting is automatically set to "Auto" and I can't change it?
R Roelli Active Member Messages 31 Points 8 Jun 23, 2020 Thread starter #5 And... somehow... if I change from 265+ back to "normal" - i now CAN activate WDR. Crazy!
Skyler Member Messages 21 Points 1 Aug 30, 2020 #6 Roelli said: Hi. I have a Hikvision DS-2DE4A220IW-DE IP dome camera. And I can't turn on "WDR" anymore. It automatically disables itselfs. Reboot did not work. I tried IVMS, but there are zero adjustments possible. Any ideas? Here is a video: Thanks, Roelli. Click to expand... So impressed with you uploading a video to get tech support. Wondering how you made it.
R Roelli Active Member Messages 31 Points 8 Aug 30, 2020 Thread starter #7 Skyler said: So impressed with you uploading a video to get tech support. Wondering how you made it. Click to expand... I used a "screen capturing software". For example: "camtasia". But... you could also just use your phone to make a quick video.
