Does anyone have experience connecting Hikvision (colorvu) cameras to a non-Hikvision NVR?
Reason is that I find that Hikvision can no longer provide the basic functionality, continuous recording but also seeing the motion markers in web playback. I want and was always able to do so until software version V3.X.
There has been enough discussion about this, see for example, thread:
www.use-ip.co.uk
www.use-ip.co.uk
www.use-ip.co.uk
www.use-ip.co.uk
Hikvision apparently no longer wants to enable this for performance reasons. The option is still there, they just don't write the markers since V4.x.
Who has experience with another NVR with Hikvision cameras that has similar capabilities to Hikvision NVR but with writing the markers so that you can search/look back on events? I'd love to hear a good model so I can (unfortunately) switch brand.
Firmware - Latest HikVision Firmware for K-Series [76 77 86 NI-K2 K4 K8] NVRs - V4.30.005 build200628 (V4 Lite with E-UI)
[20/07/20 - IMPORTANT - Some users updating to this firmware have reported that their NVRs have reset after updating, this does not appear to be affecting all K-series NVRs but if you are worried about losing any NVR/camera settings you can always go to Maintenance and export the NVR/Camera...
![www.use-ip.co.uk](/forum/proxy.php?image=https%3A%2F%2Fforum.use-ip.co.uk%2Fforum%2Fdata%2Fassets%2Flogo%2Ffavicon.png&hash=7533e7dec04b0589b5022a396a6305c5&return_error=1)
Hik-Connect - No events on playback?
We had our Hikvision 8MP ColorVu cameras set up a few days ago and it's brilliant however I was hoping to get some advice for a few things. When I go on playback in the Hik-Connect app, the timeline is all coloured in blue so I don't know which part there was motion at. I know that for some...
Intrusion detection events when continuous recording?
I have an DS-2CD2786G2-IZS indirectly connected to a DS-7716NXI-I2 NVR via LAN. The camera is set to continuously record 24x7 on the NVR. What I would like to have happen is, from 7pm to 8am, when an intruder is detected, the strobe light comes on, and the detection is highlighted when I watch...
Hik-Connect - Hik-Connect not showing motion?
Hi, I moved house about a year ago and only just put my Cctv back up. It’s the Nvr Hikvision DS-7608NI-I2/8P I updated the nvr to latest firmware 4.0 other than that nothing has changed. I have noticed that on the app if I wanted to playback it will only show continuous playback. It doesn’t...
