I was wondering how the priority of configuration works between that held on an individual camera and the NVR's config for that camera.
For example you can log into NVR and see all the connected cameras - and for a given camera and smart event set it's arming schedule etc (which ive set to be after 8pm).
But also you can log into the camera directly via it's own web URL ( eg to set Min Size for object matches that doesn't seem to be available via NVR login ), I noticed the direct camera login route for a particular smart event also seems to have it's own schedule ( which is set by default to be 24x7 ).
So does the config priority / arming schedule logic work like this
1) camera uses it's local arming schedule to see if an event should trigger
2) the NVR uses it's arming schedule for that camera to decide if the event is really raised.
ie both need Camera schedule and NVR camera schedule need to be enabled for a particular time slot for the event to make it to the 'Surveillance Center' / HIK-Connect.
Why would you configure a schedule at the camera level login, rather than via the schedule for a camera via the NVR login?
