Hello from across the pond in the Smokey Mountains of western NC.... !!!!
Question about a DS-2CD2042WD-1 cameras...., and all have been upgraded to V5.53 build 180730
A question that I'm hoping you can find an answer to.... Once a camera is mounted... Via the admin login to get to settings... is there anywhere in the settings that will tell you the size of the lenz, without physically using a ladder to examine the camera label?
Reason why I ask..... I just picked up a new in box 4MM camera (all units here are DS-2CD2042WD-1) and I know I've multiple different lenz sizes.... and wanted to determine what lenz is where, as I may want to put wider angle lenz's in areas that are closer.......
seeing that the cameras are all in different areas, inside and out, with most needing a ladder to access them..... I checked the settings but find nothing....
Is there anything anyone else has found in the settings or serial number that might remotely clarify this???
Thanks for your reply.... Jan
