Ok, that is a OEM/rebadged Hikvision camera, it may potentially support the same firmware as the 2563G0. The issue may be that as an OEM product it may use custom firmware that is not used by the original camera model, so if the main hikvision firmware does not work you will need to contact the OEM brand that rebadged this camera to source the latest firmware.
