@Dan @mysterymbps
I check "Maintenance/System Info/Record" (only on NVR direct) when I want to see the camera bitrates...
I'm assuming this is the actual bitrate the NVR (I-series) receives from each camera, but maybe it is just the bitrate being recorded to disk... but I think they should be the same?
The cameras do need to be recording in order to see the bitrate on this screen.
The page updates every 5 seconds, so I assume the bitrates shown are 5 second averages.
Another way you can get 1 second averages on a graph...
Again only on the NVR direct... go to "Maintenance/Network/Traffic"... ensure the sending green/graph line is low or at 0... it will be unless you have Hik-connect, iVMS-4200, etc. running already... then open iVMS-4200 (preferably on a local wired pc) and live view 1 camera (probably the mainstream you are interested in)...
It's interesting to change the camera max bitrate, compression settings, video quality, frame rate, etc. while watching the graph. You can also see the effect of lots of motion.
