T3rmina80r
- 4
- 3
So been running a DS-7608NI-I2/8P NVR for many years running firmware V4.22.005 build191208
Decided on weekend to upgrade to latest firmware from portal V4.61.025 build220905 which is where my problems began.
The NVR was bricked and stuck in a constant reboot loop.
After numerous attempts as the HIKVISION TFTP software was stuck on 'transmitting loop' due to not supporting larger firmware file sizes, I managed to recover using a Linux server and third party TFTP software to upload an older firmware.
I'm now running V4.60.005 build 220108, however not without the below issues ;
Uploading any of the V4.60 builds it seems I can now only run 2 cameras, as soon as a third is setup/active in the NVR it has random reboots, where log shows abnormal shutdown errors.
Im tempted to see if I can downgrade to a V4.5xxxx build and see if it will support the 3 cameras again without reboot issues.
Anyone any experience they can provide/share on current status around firmwares?
I read that there is a know issue possible with NVR units starting the 9 digit serial number with 589xxxxxx
