Hello;
This message seems to be close to my problem - it is worded differently, but I suspect its underlying issue is the same.
forum.use-ip.co.uk
My setup consists in the following devices, from different generations, but all on their latest posted firmware:
DS-7608NXI-I2/S NVR
DS-2CD1327G0-L x1
DS-2CD2347G2-L(U) x1
DS-2CD1047G0-L x2
DS-2CD2442FWD-IW x1
In the basic events section, the NVR shows a persistent warning, that there are not enough resources to support motion detection. therefore for all those cameras, I ensured motion detection is disabled.
AI by Device: Enabled for all cameras.
I proceeded in the smart events section, and started setting up intrusion detection first, then line crossing detection.
Going through each camera, drawing contours (intrusion) and lines (line crossing) where I need them to be.
I've only been able to do 3 out of 5 cameras this way. the 3rd is unfinished. When I need to finish the last setting, I get "No more rules are allowed" message. And that's the end of it.
The documentation doesn't talk at all about it, and it is therefore something one would have to figure out through trial and error.
Any thoughts about this issue, how to set this up properly?
Unrelated to the above, another question:
I was trying to find out where to set the length of the video recording after an event occurred. The pre-event is in the right place you'd expect it to be:
Recording schedule - Advanced parameters - Pre-record duration
But there is no post-record there. You'll find Post-Record only in the Capture Schedule - Capture Parameters.
Any thoughts about this one?
Thank you!
DS-7608NXI-l2/8p/s NVR - limited number of "smart events "?
I am using an 8 camera NVR, am i correct that there is a limit of 4 channels allowed to use smart events ? I tried setting up my 5th camera with smart events but it said i was out of allowance ( or something along those lines ) Box is DS-7608NXI-l2/8p/s TIA
![forum.use-ip.co.uk](/forum/proxy.php?image=https%3A%2F%2Fforum.use-ip.co.uk%2Fforum%2Fdata%2Fassets%2Flogo%2Ffavicon.png&hash=7533e7dec04b0589b5022a396a6305c5&return_error=1)
DS-7608NXI-I2/S NVR
DS-2CD1327G0-L x1
DS-2CD1047G0-L x2
DS-2CD2442FWD-IW x1
Thank you!
