Hello,
I have a DS-KV81130-WME Doorbell with DS-KH6320-WTE1 indoor station and a few generic IP cameras that work with my hikvision nvr. This doorbell has the option to add either IP cameras using hikvision protocol or generic ONVIF protocol, however no matter what I do, the device would always report Authentication failed when using onvif protocol (I know that the credentials are correct because my nvr is working just fine with them). One thing I noticed is that I have no way of selecting the onvif port (although the cameras as set to use port 80 which is the standard). I even tried adding the doorbell as an onvif camera in the indoor station (same way I use it to record from it on my nvr) and it would still complain about bad credentials.
I've updated the software from it's original 2022 firmware (that came with it oob) up to 241111 (V2.2.96), and they all had the same issue, I tried with iVMS and still the same issue.
Any help with this would be appreciated, I would love to check the cameras on my home from this device without going through the nvr.
