AX PRO DS-PDTPH-E-WE temperature sensor - setting high AND low trigger points?
Stelios
Hi guys does any one find a programming method for the wireless temperature sensor DS-PDTPH-E-WE to trigger both ways?
For example: Above 10 degrees and below -2 degrees ?
With a firmware update to version 1.4.0 you can set it differently to previous models.
For example it can be triggered between a low and high. So between 10-20 degrees. Either side there would be no trigger.
