- 436
- 28
Is there a way to hide the "No Link" message shown on unused NVR Channels?
Q:
Hi, when I have 10 cameras connected to a DS-7716NI-I4-16P and when I view the 4x4 multi-view I see 6 black boxes showing "No Link" in the centre, obviously because I'm not using those channels at the moment.
Is there a way I can hide the "No Link" message so it's just a black square?
It is definitely possible to remove the No Link error, but at the moment to my knowledge it isn't possible to replace it with a completely black, empty square. Instead, you'll be left with the Hikvision logo in the centre instead of the No Link message.Hi, when I have 10 cameras connected to a DS-7716NI-I4-16P and when I view the 4x4 multi-view I see 6 black boxes showing "No Link" in the centre, obviously because I'm not using those channels at the moment.
This has to be done via a monitor and mouse connected locally to your NVR. As of writing, this is possible on -I(x) and -E(x) series NVRs on firmware v3.4.2.
- Log into your NVR and navigate to the Menu (right click)
- Select Configuration
- Click on the Live View tab on the left hand side
- At the top of this window, click on the View tab
- Select the live view layout you wish to configure via the buttons on the bottom left of the preview panel (in this case 4x4)
- Click the [x] next to the channel name (D01, D02 etc.) of any camera you don't wish to view in the preview panel (our customer needed to remove 6 unused channels). Their D01-D16 name should be replaced with a blank X
- Hit Apply when done
- Navigate back to your NVRs live view and the No Link messages should have been replaced with the Hikvision logo.
