- 436
- 28
NVR Shows "No Resource" in Quad View
Q:
This is a question or problem we get presented with regarding the DS-7604NI-E1-4P and the DS-7608NI-E2-8P sometimes, and whilst we don't sell it, we've also heard reports of the same issue on the DS-7616NI-E2-8P too.Hello,
I've just added a fourth camera purchased from yourselves to my existing DS-7608NI-E2-8P. It's connecting and recording fine.
However, whenever I view my cameras in a quad view (2x2) I can only view three of them. The other camera has a black screen showing "No Resource". This same camera displays fine in a single view though, and I'm not even close to touching the 80Mbps incoming bandwidth limit of the 7608 (I have ~50Mbps idle at all times).
Any ideas?
Any ideas?
Unfortunately, this is an inherent shortcoming of the old DS-7600-E(x) series of NVRs connected with 3MP+ cameras, and is a hardware limitation. It only presents itself when connecting a monitor directly to the NVR and not when connecting via a web browser.
Don't worry - just because it's saying No Resource in the live view doesn't mean the footage isn't being recorded. The NVR is completely capable of recording all four 3MP+ cameras at the same time, and indeed more than four if you have a 7608 or 7616 and aren't exceeding the maximum incoming bandwidth, but it is incapable of outputting four simultaneous live feeds at their main stream resolutions.
This is as I said a hardware limitation in the NVR and is not tied to the maximum incoming bandwidth that the NVRs NIC is capable of. Our enquirer for example has approximately 50Mbps of idle bandwidth he could use, but he's still seeing the issue. Simply put, the DS-7600-E(x) NVRs were seemingly not optimised at the time with displaying 4x 3MP cameras simultaneously in mind, and certainly not the newer 4MP R6 family and 4K cameras that are popular now.
This issue only presents itself in the quad view layout of these particular models. This is because the NVR will automatically determine which stream to display based on the number of cameras attempted to be viewed simultaneously - the high resolution main stream, or the low resolution sub stream. In single view, it uses the main stream for a single camera which is perfectly fine. In 1 + 5 view, it uses the main stream for one camera and the less taxing sub stream for the other five. In quad view (2x2) however, the NVR attempts to use the main stream for all four automatically and, if your cameras are set to use a 3MP+ resolution main stream, it simply doesn't have the decoding capability to display them all at once.
Hence, one is dropped and displayed as "No Resource".
There is unfortunately very little that can be done about this. Reducing some of the camera's resolutions to 1920x1080 (2MP) should resolve the issue, but it's a bit of a workaround. Otherwise, I'd suggest using a different live view layout if monitoring is of importance, or a client PC connecting over a web browser instead.
For anyone interested in purchasing a Hikvision NVR who might be a little concerned, we currently like to recommend the newer -I(x) series of Hikvision NVRs as they have much greater hardware specifications which doesn't suffer from the above issue, and are geared up for up to 4K resolution recording.
