Four 32 channel NVRs in same switch
Ramesh
I have one uplink (Ethernet cable) for all the 92 cameras. I plugged the uplink into switch and that switch is connected to the four 32 channel NVR. The switch Each port is 1giga bite capacity..I'm facing latency issue. But if I remove any two NVRs in the switch then all the cameras working without any pocket drops. I wanted to know is there any bottle neck problem I am facing in switch?
