Jingle9109
- 8
- 1
I think I maybe going mad! I have a G1 DS-2CD2385FWD-I camera that I am trying to setup basic (advanced not normal) motion detection on. I have recently updated the firmware to V5.6.6 build 210625. I have Enable Dynamic Analysis for Motion enabled and can see the green squares. However no matter what I set the sensitivity or percentage to the green squares are always visible even if I set the sensitivity down to 1 and the percenrage up to 100 which I think means it would need to be a very large object to trigger a recording. Should the green squares always be visible regardless or should they be an idication of motion detected based on the settings? Also of note I have line crossing enabled and that seems to be working fine.
Also just to confirm I have this correct:-
Sensitivity = How sensitive the camera is to changing pixels - the higher number the more sensitive it is?
Percentage = The percentage of the boxed area that needs to change - the lower the number the more sensitive?
Thank you.
Thank you.
