H265+ corrupt stream
FireBIade
I seem to be having trouble with my 5mp G1 dome and/or maybe the NVR 4ch K1. When I set the cam to H265 it works fine, if I then add the + option after the cam reboots I get a normal picture for about 20 seconds then the time starts to corrupt, any motion is usually slightly corrupt and will eventually stop moving then after a few moments this may clear again. Any ideas what it could be? Does + mode give much in the way of bandwidth savings?
I don’t think the K1 NVR’s support the H265+ format and the reason it doen’t work. H264+ or H265 are your best options.
As I understand, H265+ is only supported on the higher end I series NVR’s.
That could be it, I will double check tomorrow.
