Hik-Connect Hik-connect configure DDNS
santi_cazorla
Hey all,
quick question, what is the "Configure DDNS" settings option on the hik-connect app. This is needed prior to "Remote Configuration" it seems.. just not sure what this option is/does?
This video shows the option I'm referring to:
It basically allows you to remotely manage your NVR.. as you would if you connected to it through it's IP address on the local network.
I see - so this creates a dynamic ddns in the background?
Also After "DDNS being enabled, the devices will be accessed via IP address in priority" - what does this mean?
