Leathers.123
- 1
- 1
I been having several issues with a Hik-Vision 2 wire video door intercom system. It’s asks to set a password including letters, numbers and capitals but when u try to access the settings on the indoor station it will only allow me to insert numbers. Stopping me from accessing the settings.
Problem number 2 is even though I have a static IP address whenever the unit power cycles it’s changes the address even tho dhcp is turned off.
Problem number 3 is when using hik connect or via the nvr I can’t listen to the audio or talk through. Only time is when the door bell goes off and the app notification appears.
Any help would be great
