Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Your network settings in the NVR need changing in the NVR if they were set manually originally.Hi all got a hikvision pro system with 1 cam all been ok . just changed ISP from virgin to bt since modem has been changed not working via wifi or internet done port forwarding all seems ok but now probs helppppppppppppppp
Me too!...In your first post you say -Bit confused
While in your second you say -since modem has been changed not working via wifi or internet
To be honest you're using a configuration that will make it difficult for anyone to assist - 2 routers. If I had to guess, I'd say that maybe you've just plugged your Asus back into the new BT router without any changes in the BT router. If so - you'll still get a connection over WiFi, as the NVR/DVR is connected to the Asus as before and so nothing has changed with regard to the internal network addressing/LAN.can view over network
Yeah - I appreciate it may have worked previously but it's far from ideal and is not a supported method of networking. With Virgin (usually) you would have had the hub in modem mode with the Asus routers WAN (internet) port connected to LAN port 1, so you'd have only the Asus WiFi network visible. Modem mode switches off all functions on the router and just forwards everything from the internet to the Asus. Before you switched suppliers, the LED on the Virgin Hub 3 would've been lit solid pink for modem mode, while if it had been in standard router mode it would've been solid white.I have managed to view with hick connect app via WiFi . The set up is internet/ optics - Bt Hub 2 - Ethernet cable - Assus router - Ethernet- hick vision Dvr - ip cctv .
We have to have assus router to extend WiFi so have got 3 WiFi networks Bt / Assus 2.4 - 5G .
This set up has worked for many years when on virgin all ok but know on Bt can’t view cctv via internet mobile phone or web browser Google chrome / IE / Safari / Firefox
regards
Richard
Sounds like a setup for double NATting. I assume the BT router has the public IP from the VDSL WAN and port forwarding as well. Check the BT router logs for incoming WAN connections, establish a baseline for troubleshooting and switch off the ASUS.I have managed to view with hick connect app via WiFi . The set up is internet/ optics - Bt Hub 2 - Ethernet cable - Assus router - Ethernet- hick vision Dvr - ip cctv .
regards
Richard
Yeah if you read his setup, he's using it as a WiFi extender so is a headache of a setup......Sounds like a setup for double NATting. I assume the BT router has the public IP from the VDSL WAN and port forwarding as well. Check the BT router logs for incoming WAN connections, establish a baseline for troubleshooting and switch off the ASUS.
