Setup:
1. 3 ip cameras with audible alarm option and flashing light option all acusense capable. AX pro hybrid up and running, NVR present.
2. . AX pro has a dedicated "outside" zone with added cameras and SMART event intrusion detection. Working ok - if the zone is armed it triggers alarm and sends clips to hik-connect app etc.
What i want to achieve is:
When zone "outside" is armed in AX PRO the audible /flashing light option is active ( independently of alarm schedule configured inside the camera). Is there a way to achieve this?
i can play with ISAPI and have a lot of experience in node-red and other automation.
i have a node-red backend reading all information from ax pro so i can check the zone arming info and then submit a PUT/POST via ISAPI to turn on those notifications on this camera one after one but not sure if such operation is possible via ISAPI. It will be also great to disable whole alarm notifications from camera to hik-connect during staying at home (ax pro not armed)
