I bought mention model but it can't ;
1. Zoom (100%) vehicle/ human entering intrusion zone..
2. Put back the PTZ to it's initial position once other camera (link to PTZ) detect intrusion ..
I'm not sure if point 2 is possible, what do you mean by the other camera being linked to PTZ?
The Duration setting on the smart tracking page refers to how long a target will be tracked for, the lower the value, the shorter the tracking time.
Setting this to zero will mean that the target will be tracked indefinitely, or until it exits the camera's view.
I've been told by the seller - if i link other VCA camera to PTZ and once there's an alarm trigger from the VCA camera (intrusion or line crossing).. the PTZ will shift the camera to the preset position. It work.. but im a having the trouble of returning the PTZ to it's initial position.
What firmware is the camera using? It's the sort of problem that could be caused by using old firmware.
If you have set the initial position properly, maybe try resetting the camera to its factory default settings and try again.
