Hikvision DVR HDD Replacement Question
TheOn3
Hey all
I recently replaced by original HDD with a newer higher capacity drive. What I want to know is, will this automatically increase the footage that it stores for or is there a setting to increase the time it stores the footage for?
Thanks in advance!
Hi @TheOn3
If your recorder is set up to record continuously 24/7 (and you haven't manually put any other settings in place to restrict recording), then a larger HDD should automatically give you more days of recording.
Hi @TheOn3
I don't think it continuously records, but records in bursts when it identifies movement.
If the regularity of the motion detection triggers (e.g. an average of 50 a day, 75 a day, 100 a day, etc...) hasn't changed drastically from before you changed the HDD, then yes, it should hold those motion event recordings for longer with the larger HDD.
