hikvisionMe
- 6
- 1
I have recently acquired an indoor and outdoor station, DS-KH9510-WTE1 (B) & DS-KV8113-WME1 (B) respectively.
The aim is to control (i.e. open and maybe close) main and side gates. The side gate is a maglock whilst the main gate is a sliding gate motor; the motor is a Nice Robous 1000.
My question is around the wiring setup; for the maglock a standard connection from NC1 and COMS line on the DS-KV8113 is sufficient for opening the gate. However for the sliding gate motor, the datasheet simply shows a connection to an NO and COMS line. Although the datasheet doesn't explicitly suggest a relay, would I need a relay between the outdoor station and the motor?
Is a direct NO & COMS from outdoor station to motor correct? Bearing in mind that NO & COMS line is a 12 volts
I have attached the datasheet of the Nice motor and the outdoor station.
Any recommedatuin is welcomed.
Thanks.
Thanks.
