C chrizzo Centurion! Trusted Member Messages 100 Points 18 May 6, 2022 #1 Hi, its not easy to clean an thermal modul from a thermal camera. Because its a Vanadium Oxide Module, you cant use a towel or cleaning cloth. Any ideas?
Phil Administrator Staff member Messages 5,134 Points 113 May 6, 2022 #2 Does it make any recommendation in the manual for the camera?
C chrizzo Centurion! Trusted Member Messages 100 Points 18 May 6, 2022 Thread starter #3 Phil said: Does it make any recommendation in the manual for the camera? Click to expand... only for the case. The lens is very special. I will try a special cleaning active foam (15min influence) and then clean it with clean water.
