I'm looking to add a switch to my set up and consolidate into one switch with additional capacity for future needs.
I'm using 8 ports at the moment anyway but can route a few more devices through either one of these options
Narrowed it down to these 2 gigabit options. They appear to be of the same family one being 24 port and the other the 16 port version.
The questions I have is how noisy are they? Do they both have the same fan setups internally?
Is it ok to go unmanaged or should I be considering a managed switch? My thinking is if I have a range of PTZ and static devices with varying POE draws it might be good/better for me to be able to assign POE budgets by port.
Is this do-able in the unmanaged switches or is it all Plug and Play?
I have read the Data spec sheets for both and aside from the max power ratings I could not see the Power draw at standby and low level activity. There will be 4 Static cameras and one PTZ attached all POE+(AT)
24 Port
16 Port
For the most part they will be left on and doing their job and once set up very little messing about afterwards so watts consumption would be good to know so I can make the best choice.
The Cat6 runs to the cameras range from 5m up to around 20m. It's all very within capacity for either model.
Many thanks
24 Port
16 Port
Many thanks
