Hi guys,
If the cameras are connect to the NVR are you unable to see the IP addresses of the cameras on SADP? However, if it is connected on an POE the IP address would appear?
Additionally, I have a property with the IP cameras are set up already but they aren't linked to the NVR I have.
A) How do I find out the IP address? (Via a switch then SADP?)
B) I don't have the username/password - apart from getting up a ladder to reset them is there another way?
I saw a post by use-ip who explain to export the file from the SADP and send this to hikvison technical support. If step A doesn't work is there an alternative to resetting?
