videotoolbox info: Using Video Toolbox to decode 'h264'
main debug: using video decoder module "videotoolbox"
main debug: looking for audio decoder module matching "any": 21 candidates
g711 debug: samplerate:8000Hz channels:1
main debug: using audio decoder module "g711"
main debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in /Users/sofa/Library/Application Support/org.videolan.vlc/lua/meta/reader
lua debug: Trying Lua scripts in /Applications/VLC.app/Contents/MacOS/lua/meta/reader
lua debug: Trying Lua scripts in /Applications/VLC.app/Contents/MacOS/share/lua/meta/reader
lua debug: Trying Lua playlist script /Applications/VLC.app/Contents/MacOS/share/lua/meta/reader/filename.luac
main debug: no meta reader modules matched
main debug: `STREAM' successfully opened
macosx debug: Activated assertion NoIdleSleepAssertion through IOKit (33995)
main debug: Buffering 0%
main debug: reusing audio output
main debug: VLC is looking for: 's16l' 8000 Hz Mono frame=1 samples/2 bytes
auhal debug: attempting to use device 0
auhal debug: using default audio device 77
auhal debug: Current device has a latency of 1375 us
auhal debug: output layout of AUHAL is Stereo
auhal debug: selected 2 physical channels for device output
auhal debug: VLC will output: Stereo
auhal debug: Current AU format: [8000.000000][mcpl][9][8][1][8][2][32]
auhal debug: analog output successfully opened
main debug: output 'f32l' 8000 Hz Stereo frame=1 samples/8 bytes
main debug: looking for audio volume module matching "any": 2 candidates
main debug: using audio volume module "float_mixer"
main debug: input 's16l' 8000 Hz Mono frame=1 samples/2 bytes
main debug: looking for audio filter module matching "scaletempo": 16 candidates
scaletempo debug: format: 8000 rate, 1 nch, 4 bps, fl32
scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
scaletempo debug: 1.000 scale, 240.000 stride_in, 240 stride_out, 192 standing, 48 overlap, 112 search, 400 queue, fl32 mode
main debug: using audio filter module "scaletempo"
main debug: conversion: 's16l'->'f32l' 8000 Hz->8000 Hz Mono->Mono
main debug: looking for audio converter module matching "any": 8 candidates
audio_format debug: s16l->f32l, bits per sample: 16->32
main debug: using audio converter module "audio_format"
main debug: conversion pipeline complete
main debug: conversion: 'f32l'->'f32l' 8000 Hz->8000 Hz Mono->Stereo
main debug: using audio converter module "trivial"
main debug: looking for audio resampler module matching "any": 3 candidates
main debug: using audio resampler module "samplerate"
main debug: Buffering 4%
main debug: Buffering 7%
main debug: Buffering 11%
main debug: Buffering 15%
main debug: Buffering 19%
main debug: Stream buffering done (15998 ms in 16390 ms)
main error: buffer deadlock prevented
main debug: Decoder wait done in 0 ms
main warning: buffer too late (-12995844 us): dropped
main warning: buffer too late (-12955860 us): dropped
main warning: buffer too late (-12915865 us): dropped
main warning: buffer too late (-12875871 us): dropped
