@Magwhy
To enable rotate/corridor mode on the new G2 AcuSense cameras you will need to switch the cameras VCA Resource mode to Monitoring, unfortunately, although this does enable the rotate setting it also disables all the main Smart Events. I believe Hikvision made this change because the Smart Events were not behaving correctly or triggering accurately when set on a rotated image.
