DS-2DF9C435IH-DLW with latest code. Was using Hik-Connect commands to control it and I did "something" on the lower right of the screen (I know not what, exactly), and the image inverted (all up-side-down).
Cannot find a command to change this (not unreasonable as it is always mounted in one position).
Copied Config File, Restored and image was correct. Loaded Config File and image inverted after auto-reboot, so there's something in the file.
I can Default all settings, but the config is quite complicated. Any way around this? Seems like a bug.....
