AX PRO Integration of Ajax Light Switch with Ax pro?
Has anyone managed to integrate the Ajax Light switch in to Ax pro ? Is it even possible ? I would like to use the ax pro motion sensors to automatically turn on the light in the hallway.
If it's not, what's the solution ? Unfortunately hikvision doesn't have the smart bulbs or smart light switches, the same with Ezviz.
Thats is not possible, however if you add Ajax hub into equation, then yes. Both brands do have API, but Ajax API is closed API which requires api key.
I work with integrations and i made an phone app that can work with multiple systems
