I've connected my 2CD2386G2-ISU/SL to an LED floodlight via a photocell using a Solid State Relay (SSR) and it was quite an adventure. First off, the camera doesn't output any current from the alarm outputs, which on the 2386G2 are marked IN|G|A1|B1 on the plug. I figured that G and A1 were the correct outputs but when that didn't work, used my trusty multimeter to check continuity and found that I needed to connect A1 and B1 to close the circuit. These are also dry contacts, so despite having an SSR, I needed a power source to drive the SSR, which was easy enough. So now I have the -ve of the power source connected to -ve on the SSR, the positive on the power source goes to A1 on the camera and the B1 is connected to the +ve on the SSR.
All good so far. Except that all SSRs appear to have "leakage current" even with a "snubber" fitted. So once the photocell triggers the SSR, I get an under driven LED that is then energised to full power when the A1 alarm is triggered, set to intrusion and event line crossing in the camera. It's not an unpleasant effect, similar to those front door lights that are dim when on and brighten up when the PIR is triggered. Plus under driving LEDs doesn't apparently impact their function or lifespan, so I'm not too worried. Now I just have to fine tune the smart events and photocell lux setting.
