I've a couple of questions to help my setup, not sure if these are better placed as individual questions or combined (apologies for any etiquette mistakes)
Capture settings
The setting under : Storage : Schedule Settings :Capture
I don’t understand what these are used for, can you use it to email pictures on “Event”
The Help file suggests that it stores images on Net HDD / Memory card. This doesn’t seem the most useful, is there a more useful way to use this.
Event / Smart Event
I have the Smart Event (intrusion detection / Line crossing) working well and sending emails.
Is there a way to set the events to trigger emails to send only between set hours? (eg on a night when activity is more suspicious)
Is there a way to change the picture quality of the images sent? or ideally a short video ?
Live view – Via web Browser and IVMS
Sometimes Live video doesn’t appear and changing to sub stream and then back to main stream works and then it settles down.
Current settings for Live view are
Play performance : Balanced
Rules: Disabled (What is this?)
Camera names
The camera names don’t always seem to pull through to the NVR.
I have changed both the OSD name and also the name on System : System Settings : Basic but it isn’t updating the NVR
Illegal Logon
I managed to set this on one DVR, but cant find the settings (to email on illegal login)
Turret Cameras
Why is the “up” label next to the SD card which isn’t protected by the cowl? Surely this is a weakpoint for ingress and should be under the cowl ?
Is best practice to rotate the camera physically so the SD card is protected and then flip the image?
Many thanks in advance
Capture settings
Event / Smart Event
Camera names
Illegal Logon
Turret Cameras
