Multiple Ezviz NVRs
mariusmeyer
Good day
I have 2 Ezviz X5C NVR's and 8 C3W husky air cameras. Is it possible to link the 8 cameras to both NVRs at the same time? We have 2 houses on the property and would like to setup a NVR in each so that both families can have a permanent screen up with live view and also the benefit of backup recording.
If you are saying that you can add all of the cameras to the same LAN, and the NVRs have the stated capacity to cope with the number of cameras e.g. 8 cameras in total on an 8-camera NVR, then it should be possible.
Put the cameras on the LAN and give them LAN IP addresses.
Use manual adding to add the cameras to both recorders.
Unless there are limitations with those NVRs that I am unaware of - we don't have any experience with them.
