I find many DS-7716NIxxxx but none are SP. I'm not sure what the SP stands for, but am nervous to pick one of the other DS-7716NI firmware at random Which would map to mine?
I tried calling support but Hikvision was like 'no i cant tell users anything about firmware, I mean, yeah this firmware exists, but the unit is no longer in production so installers only'
Is there an installer who can post the firmware? I am currently on V3.4.5 Build 170518
My issue is that although cameras are setup properly and work when I use virtual host or when I plug directly into router and then for either case I use OLD Internet Explorer, then I see images just fine.
But if I try to use the NVR itself, I see only a black screen. Also if I use a modern browser I am told to install a plugin (USSCWebComponent) that does not work (have installed it many times). Since the NVR sees a black screen, it is not able to record, nor can I program alerts within the NVR. I should be able to do them on each camera but thats a hassle I should not have to deal with when I have an NVR. BTW cameras are also Hikvision
