Hi I have a system I'm installing its Hilook by hikvision I've connected 3 cameras to the NVR through the POE terminals which is fine, my problem is adding a camera over the LAN.
It's found the camera and I've added it manually but I'm getting the error code of network unreachable when trying to view, could it be that there's insufficient WiFi signal to view.
Thank you.
Thank you.
