New Camera not getting an IP / default or showing in SADP?
s31vec
Brand new out the box ANPR camera, can't see it via IVMS or SADP , layer 3 switch can see MAC but no IP at all.
Have tried reset button 10/20/30 sec no change.
Tried 2 switches and 2 PoE injectors.
IR lights come on for a bit and then nothing.
Any help please?
Hi @s31vec
How are the PoE switches/injectors connected to your local network? Are they connected directly to the router?
Do you have iVMS/SADP installed on a laptop or desktop PC? If it is on a laptop, are you hard-wired to the same network as the cameras or using a WiFi connection?
So...SADP picks up any other camera connected to that cable just not that Camera, have tried everything can think of now getting it RMA'ed :(
Thanks @s31vec
If other cameras are working on that cable and PoE switch/injector then it does sound like it could be faulty.
Have you checked that the PoE Injectors/switches you are trying support the PoE standards for this ANPR camera? Some ANPR models use more power and require an injector/switch with more power (e.g. PoE+ or High PoE output).
