Hi all,
I want to install cameras in a house, and I have several doubts that perhaps you can solve.
I had thought of an installation with about 6 Dahua brand cameras, because I know there are good cameras and a prestigious manufacturer. Doubts with the following:
1.- Analog HD cameras VS IP cameras
The wiring will be all new. what's the best option, use HD analog dahua cameras (with Balluns), or directly IP cameras? The doubt comes because analog cameras are much cheaper than IP cameras, and to view them I am going to connect to an XVR as well.
2.- Quality analog VS IP cameras
What cameras look better, and with better fluidity, analog or IP cameras?
3.- XVR or NVR.
It is obvious that if I use analog cameras I will need an XVR and if I use IP an NVR. The problem is that the XVR or NVR is going to be located in a work room, so it would have to be one that have no fan, or if it does, one that makes very little noise. Any recommendation? I have a friend who has a Dahua NVR, and it is very very noisy. Impossible to have it in a room where we work.
4.- Infrared technology, led or color2.0
I have seen that there are different display technologies at night. Do you recommend any in particular?
thank you very much to all.
greetings
3.- XVR or NVR.
greetings
