Newbie setup: NVR 7716 POE - Should I setup cameras plug n play or manual?
Lemonjuice
Hi all,
I have NVR 7716 which is POE and a bunch of HIK Vision cameras and intercom.
I wanted to ask is there a recommendation on weather I should set the cameras up as "plug n play" (which the NVR setups them up and they are on a separate subnet). I'm not sure what will be required for the intercom.
Or should I set them up manually and put them onto a separate VLAN on my network. I assume this would mean I dont connect the cameras to the NVR POE ports (which is kind of useless having a POE NVR)
Any thoughts or experience would be great.
Most people use the NVR's POE ports to connect their cameras.
The intercom will need to be separately supplied - connected to your network.
