no video on the apps or in a browser
Frankvu
Hello,
I have an HNRA10-64 with 28 DS-2CD2085FWD-I cameras
We are having an issue with video on the android and apple app as well as in a web browser. Every day, we lose video to those remote viewers. We do not lose video locally on the monitor or television (connected to HDMI 1 and 2). We can be onsite and no video on the apps or in a browser (older version of IE).
Hikvision will not support me because they say I bought from a reseller. The reseller says I have to unbind; but, we never set up Hik-Connect or enabled any of the platform access options. They say until I do that, the issue will not resolve. I've followed all suggestions I can find on the internet and the issue simply will not resolve. I can bring the camera up remotely and have no issues with video...it's only when I use an app to view the cameras. We are using a variety of apps - NVMS4200, iVMS 4500, android, apple and Internet Explorer 11 (pnly I use that and only when I need to restart the NVR)
To resolve the issue, I reboot the NVR remotely and everything is fine for another 24-36 hours. Does anyone have any idea as to what the problem is? The reseller told me my internet is dropping; but, it's not. I ran wireshark and there's no issues that come up. I use a Sonicwall TZ350 and have the cameras on a separate LAN zone from the network. Cameras are also on their own Cisco POE switch. I do have a route to access both LAN's; but, when I shut that down, the issue remained. The firewall is showing no intermittent issues and the internet provider is not showing any issues (1gb cable modem).
Thank you
Hi @Frankvu
What firmware is installed on the 28x DS-2CD2085FWD-I turrets?
I don't know what the latest firmware for the NVR is, but I would check with Hunt CCTV to make sure that this is up to date too.
If you have used iVMS-4500 and added each camera individually to it, then you will need to unbind them from your account, as this is the old discontinued version of Hik-Connect - here's the guide for doing this:
As the NVR isn't a Hikvision model, this itself cannot be added to Hik-Connect.
You could try Hunt CCTV's app, which looks to be called "Guarding Vision".
Or, to use Hik-Connect, I think you'll need to put every camera on a POE switch so that they are connected to your local network, and then add each camera individually to the app.
But, you will need a microSD card in each camera to view recorded footage and receive notifications if you're doing this.
