NVR DS-7604NI-SE/P limit resolution
Costin
I have 4 NVR's same model DS-7604NI-SE/P and each one with 4 IP cameras model DS-2CD2442FWD-IW.
One of the NVR's has a problem: does not allow anymore to select any other resolution than 352x288 (please check the pdf file attached, with capture screens from the bad NVR and a similar good NVR compared).
I've tried already to reset the NVR to factory defaults without success.
I would try to rewrite the firmware but I cannot find the firmware for this model to download.
Any suggestion how could I solve this problem?
Thank you,
Costin
I've tried with 4096 and other different values, there is no difference, resolution remains greyed out... The IP camera is the same...
I had to log into the camera's web gui, not the NVR's, in order to change the bitrates. On the NVR's gui, the bitrates are grayed out.
Phil, thank you very much for the link!
fullbogie, I've just moved the camera from a good identical NVR, to the bad one, without modifying anything in settings... The main problem still remains, the video resolution option is greyed out on the bad NVR...
