NVR for DS-2CD2387G3-LIS2UY/S(L)(RB)
alexdel
As the title says I need your opinion on what NVR should I buy for my new camera setup with 4 DS-2CD2387G3-LIS2UY/S(L)(RB)
Although I have read the review of @JB1970 about the g3 model, and I was little disappointed that Hikvision has replace the 1.2 sensor with 1.8 as also the smaller size of the lens comparatively to g2 model. But for my case it suit my needs this hybrid system because I don't have a clue if Colorvu will be enough for the light conditions I have (I mean with the white led off of course) or if i will finally use them with the IR.
So... I don't have much requirements. It's about my cottage house just for viewing and of course perimeter protection. So I suppose it has to be an Acusense model.
Thank you
Your cameras are Acusense/ColorVu, therefor any NVR capable of decoding 4x 8MP streams will be fine. I suppose go for M series NVR
Dear @trempa92 thank you for your response.
Ok... so help me a little bit cause I could say that I am new Hikvision user although I have a 7732nxi-i4/s with 21 cameras already.
So if I use AcuSense cameras there is no need of using AcuSense nvr? All the functions of an AcuSense nvr will be available even if I buy an NI nvr?
Also what the M series has to offer comparatively to I series or K or Q or S series. I am a little confused regarding the NVR's and Hikvision website doesn't help a lot. For example if I select the section of all pro series nvr's in the subseries list doesn't have the option of M models.
I can find them only in ultra or deep in mind series. But in there you can find nvr's models starting with 76xx or 77xx codes which if I am not wrong are pro series models right?
Of course in my setup I will need something basic cause is for residential use but there are so many nvr's and I am totally confused.
Thank you
If you have acusense camera acusense NVR is not needed. As camera have algorithm for detection on itself and it will pass an event detection toward NVR. So NVR wont do any analytics but camera itself and just notify the NVR.
M serie is best hardwarewise. Gives more bandwidth, decoding capability compared to Q,K,I series
If you want you can go with acusense NVR as well if its not too much of a difference between prices
Acusense M serie
Normal M serie
Only advantage of acusense NVR is Acusearch function. On hik connect and local playback you will have human and vehicle icons for event on timeline bar.
But now some NVR models which aren't acusense also support acusearch(Sometimes only with customized firmware)
I can post here for M4 only if it supports acusearch after i see with Hikvision, datasheet is not saying anything. Doesnt mean it does not support as their datasheets can be outdated.
Acusense M serie
Normal M serie
Ok. Acusearch is very important so I will probably need an AcuSense NVR like the one I have now in my other system. But M series with AcuSense (iDS models) is hard to find in my country and also I think I don't need something so good for my 4 cameras residental setup, except if you thing that I will have issues if I choose other NVR model.
An issue I faced with my other NVR that I bought 3 years ago (DS-7732NXI-I4/S) is that Hikvision doesn't support it anymore so there will be no updates for it as I know.
So I would like to buy an NVR that will be newer series model (maybe also support the new GUI5) that Hikvision will continue to support it for some years.
I don't know which series are newer and which of them are older. So some help will be appreciated. The only thing I need is to have POE ports on it for my 4 cameras in order to avoid the installation of a poe switch.
Thank you
Oh sorry, i forgot you mentioned 4 channels.
I'd go with ids-7608nxi-m2/x. Good bandwidth, good decoding capability and a extra spots for expanding current surveillance
